Looked around but didn’t find anything on this, let me know if I missed it.
When at idle speed, the shift from 1st to 2nd seems a little...rough I guess you would say. There’s a good jolt when it occurs.
It usually happens while cruising a parking lot to leave for me.
Also, it seems as though the engine is off balance when it does this - no expert here so be easy!
This usually happens when I am coming to a stop or starting from a stop. Happens sometimes on a cold start too.
Could this be a timing issue, a valve isn’t firing, something that new plugs could fix, or should I be thinking elsewhere?
