Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
There was a weight bolted to the rear frame, just above the rear leaf spring (had to remove it to get the upper bolt out) Not sure why it was there? Anyone else seen this.
I don't know how I didn't see this before but as I was re-torquing the Stage 3 bolts I came across this item. It is a large rubber pad mounted between the frame rail and bed box on the driver's side.
