R
Rick@FreedomMotorsports
Guest
Our most popular UCA is the ICON Delta Joint, followed by RPG but like 5 to1.
The Delta Joint has a 5yr warranty and is enclosed so it will not wear out as quickly as an exposed uniball. The ICON DJ does require greasing every 3k miles or every oil change. A standard uniball is not recommended to grease unless with a dry lube is best. I had the ICON DJ on my GEN1 and it worked great but I had Method 0 offset wheels. They are designed to work with stock wheels and tires but recommend a wheel with at least 6mm offset which is about 1/4" further out. And of course, the ICON Alloy wheels are 6mm offset.
If you are planning on locking the lowers, then in my opinion the ICON's are the best since you can make adjustments while on the truck without removing. You do need to find a shop that knows how to make caster/camber adjustments from the UCA though. A lot of tire shops have no idea.
Hub-Centric wheels is what you want. I have seen multiple people that have broken lugnuts when off-roading with lug-centric wheels. If I only seen it once, then I would think that person didn't torque them correctly but after seeing it several times, torque wasn't the issue but the forces on the wheel and lugnuts when off-roading. I personally have only had hub-centric wheels and will never get lug-centric. I have bent 3 wheels when off-roading over a period of a few years but have never broken a lug. I do recommend carrying a few with you, fronts aren't too bad, rears not so much to swap out.
I do have one more ICON DJ in stock that I will sell at a discount. Message me if interested.
Thanks,
Rick
Thanks,
Rick
