Carlos C
Hello!
Installed the ICON leaf springs on my 20 Raptor and now my steering wheel is off center to the right.
I left all bolts loose until the leafs were loaded then I torqued everything. The axle seems to be shifted back on the passenger side. I measured from the tire to the fender and its about 3" on the drivers side and 3.5" on the passenger. I know this will not be an accurate reading but a 1/2" definitely tells me it's off. It's also visually off center. I checked the 2 pins that line up on the axle and are perfectly seated. I also loosened the U bolts, front Leaf bolt and pulled the axle forward with a ratched strap to the frame. It moved a bit but not much. Only other thing I can do is loosen the U bolts plus the 2 bolts/pins that hold the leaf packs together and maybe it will shift enough when I pull the axle with the ratchet strap to the frame again. Any suggestions? think I've tried it all, maybe I just got a bad leaf pack with the holes punched off center. I will call Offroad Alliance and ICON on Monday if I don't get this resolved.
Thanks!
Bruno
Thanks!
Bruno
