ICON Ford Raptor Rear Hydraulic Bumpstop System Official Information
Blackhawk
Looks good. thanks for the pic, are you running these Icon multi-rate springs on a supercharger? If so what set-up are you using? It sounds like a standard set-up may be best if no additional weight in bed etc...
Icon spring
Rmeir
This is not a supercharger.
I know it is higher then normal, I used all the leaves. I have a box with tools and other equipment which probably equals out to 110lbs or more. I will try it out at the GLRE time attack 1 in Ohio. If there is an issue, I will remove a leaf.
