FishFreak
I'm rebuilding a used set of Icon 3.0 Stage 1 resi shocks and their triple bypass version at the rear, and installing them for the first time on my 2014 Screw. Any suggestions for hot shock tuners that can improve these? Also, what else is a good idea to replace while I'm in there? I'm sure I'll need new UCA's just from the my mileage, so aftermarket suggestions appreciated, with an explanation why would be appreciated.
Backstory: I picked up a well beaten set of Icon 3.0 Stage 1 front and rear shocks off marketplace for $500 and I’ll be sending them in to either Icon or an independent shock rebuilder like Rock & Road performance for rebuilding. Anyone have feedback on that? I know Icon are not King or ADS shocks, but they’re 3.0” mono tubes, which can’t be a bad place to start from if you're on a budget, right? Wondering if y’all know of any hot shock shops that could actually improve the shocks? PO was a thrasher, jumped his G1, said he always ran them on the softest setting or just a few clicks stiffer?
Of course I'm going to repaint the bodies and springs. Interestingly, I called Icon and got a return service number, and talked to John on the phone who suggested I NOT powder coat my old springs. Said you can easily change the heat treating of the spring and possibly damage them! He said just Rustoleum rattle can them! Hmmm, springs may be a challenge to rattle can right? Any ideas here?
I’m pretty excited to get my paws on these cuz I was just looking at cheap options like rebuilding G1 or do the illustrious G2 swap with the KHC front top bucket kit. I feel both too be compromises to any 3.0’s with triple bypass R’s, am I right?
Also, I’ve got 140k easy hwy miles on my Screw. When installing the shocks, I’m thinking of upgrading UCA’s, tie rod ends, what else is mandatory to replace? I’ll add those LCA pivot alignment cams. Should I go braided brake lines and what kind suggested? How about IWE upgrades while I have it apart? Please include brands and models, good and bad. I like higher quality than OEM, but the BEST VALUE is key with me, no $3,000 uca’s, no $275 billet China Amazon junk uca’s. Will consider Icon, SVT, RGP, etc, but leaning towards cheaper chromo tubing rather than spendy billet. I’d be more excited if those alum uca’s kicked the uniball angle out, not 90 degrees to arm where it seems to be stressed at extension. Light off road, mostly blasting around the streets and towing my bass boat. TIA !
