ICOM 4100 Radio Help
MnFlyer
MN
Most people put in a ham radio so they only need one radio and ham radios can be lower costs.
A modified ham radio, if you select the right one and perform an extremely minor modification, will work on business band, MURS, GMRS, FRS, ham, etc, so you can have one radio that does it all. Yes, it is not legal to do so in the US. But the use of non-type certificated radios on other services is a fairly common one.
I would never suggest anyone operate in such a fashion that is contrary to regulations. However, I also believe that is a personnel choice. Your chances of actually being prosecuted for such actions, assuming you are not using the radio in such a way that you would not get in trouble if the radio were otherwise legal, is infinitesimally small.
Where you have to be careful is talking to people about what you have. Some hams can get pretty persnickity about modified radios, and you have to keep in mind you are doing something that is technically illegal. Most don't care, but a few are very vocal.
Also, keep in mind that MANY of the "legal" race radios out there are not legal the way they are used. For example even if the frequency and radio are legal, is the operator authorized under a specific license? If you transmit on Weatherman using any radio at all, is that legal?
A valid concern (and why licensing and type certification exists in the first place) is that using a less than legal radio does require a specific level of knowledge. You (or someone) have to program in the frequencies and tones. You have to make sure you are not using a frequency that might cause interference to legal users. In other words, you don’t just dial up whatever freq you want and start gabbing. Doing so on the local police dispatch frequency, ambulance frequency, or aviation frequency, is certainly a good way to get noticed and quick. Causing interference to those services because you have selected a frequency not on them but too close will also get you noticed.
With that all said, I use three radios in my truck. A Yaesu FT8900R (VHF / UHF), the body is under the back seat and the control head is in the overhead sunglasses holder. A Kenwood TS-480SAT (HF / 6M), the body is under the back seat and the control head is on the front dashboard. And a Uniden BCD536HP scanner, the radio is in the center console and I sue a repurposed old cell phone for a control head on the overhead, near the AUX switches.
T!
Excellent.. that’s what i was thinking but i just lacked the knowledge.
I fly for a living, so messing around with the feds is not something I’m willing to risk and I’m kind of a stick in the mud for regulations since that is my livelihood.
Ill get my technician license and just have more toys in the truck.
Thank you sir.
MEIRONMAN207
¿Goin somewhere...What are RU waiting 4?
Maine
Thank you sir.
What I can add to help you out maybe? Is that about 6 or 8 months ago I was also researching and getting educated as to what coms to install in my beast...I ended up with the ICOM ID5100. Also I stated twice to a previous poster to help them out and didn't listen to later state if they had known. My post quoted, "...but after looking at the size and difficulty, I figured once I got the right tools, etc., and add the risk of ******** it up and not an electronics engineer...for 35 bucks, I'll let the experts do it...I did inspect the boards after I rec'd the units, and it was a clean job and my rigs work correctly. So I can't complain nor worry about warrantee coverage."
I figured that I let the company/seller do the work, guarantee the work and know that someone else more knowledgeable and with the correct tools do it legally and for $35 its a no brainer. Plus I can show I didn't alter the rig myself...It's legal to do/have the work done, just the operator has to be certified and operating under legal permission or license. I do have both. My $0.02s.
OriginalToken
I encourage everyone to get a ham license. It is easy and opens up a lot of legal communications options not otherwise present.
But even doing so you may not be able to do everything you want and still be 100% legal to the letter of the regulations. You may still occasionally face a choice of not doing something or not worrying about 100% compliance. This can be particularly true when wheeling with a larger group where everyone does not have the same setup.
This is my install in my 2018 SCREW:
T!
