I 100% understand your thought process behind the 2.5 vs the 2.0 bump. The 2.5 bump quite possibly is major overkill for this application. Not that it is a bad thing but I would imagine that if ICON is putting out a kit with 2.0's it probably does the job just as well as the 2.5 for this application.
I look at it this way. The 2.0 or 2.5 bumpstop is an emergency item. If your shocks are tuned correctly 99% of the time they are doing 100% of the work. So the difference between the 2.0 and the 2.5 doesn't really matter in this application. Remember while these trucks might weigh the same as a trophy truck what we are doing with this is vastly different.
I'm not saying that using a 2.0 is superior to the 2.5. I just wouldn't discount the 2.0 so quickly. Just because one company is offering a 2.5 bumpstop doesn't mean that 2.0's are inferior to this application.
Let me put it to you this way, I'm not going to use 99% of the time, 100% of the time to make any claims because we all know statistics like that are derived out of peoples asses. It's not hard to watch any of the available bump videos and see that they get used way more than just 1% of the time. In fact they are a critical part of the suspension system working properly, especially out here in the desert southwest.
Let's take the comparison of a Trophy Truck to a Raptor. It's not uncommon for a Raptor to be loaded up in the bed with 500-1000pounds when offroading. The weight of a TT is very balanced with fuel cells, battery's, tires in the rear etc. Here is the difference. Most modern day TT are running 4.5" 5 Tube bypass shocks with a 3.0" coilover, plus a 2.5" bump to control the insanity. And as most of you know, they have at a minimum 15-20" of bump travel to control all of it. Now your Raptor with the same weight over the rear axle and at best a single 3.0" 3 tube bypass and leaf spring is suppose to control 14-20" whoop sections at 80mph with a whopping 4-6" of bump travel. You could actually make the argument a Raptor is in more need of a proper air-bump than is a trophy truck. So I guess the question is what is the right size bump? I'm no expert so I won't throw out statistics for the world to see and possibly get the wrong impression, I will leave that up to the experts. But what I am certain of in the world of offroading is extremes exist, and I'm not sure if the term overkill has anyplace in it. Hence why BFG now makes a 42" race tire, King makes a 4.5" shock etc...
I want to apologize to the guys at Icon if anything I have commented on has derailed their thread. I will recuse myself from any future commentary.
Tizz
