Blue Monster
one of the first things I noticed is how weak the fan is.....takes forever to cool the vehicle down.
Take it in...mine had a diagnosed bad evap somewhere behind the dash.Yeah, the HVAC in this truck really isn’t that good. I’ll set most of my cars at “75 Auto” and im generally comfortable. This truck has a hard time cooling down when it’s 107 out. Plus it seems like it’s either cold or hot. Nothing in between.
Anyone else find that the max fan speed on the HVAC system is just not that powerful?
When I put the truck on max A/C - the air is pretty cold, but the velocity and volume is just not that high compared to other cars. It feels like the max fan setting is only 8/10 of what it should be. The airflow from the left and right side vents is also noticeably weaker than the center stack vents.
I also noticed today that if I crank the fan to max, and manually turn on the middle (dashboard) vents and the floor vents simultaneously, almost no air comes out of the dashboard vents. Like, less than even a gentle breeze. Can anyone else check this and see if their truck does the same thing?
