How to install Bull Ring on Short Bed F150; Location of Stake Pockets
frunko1
Truck 2013 F150 Raptor, 5.5 Bed. Have Bakflip Fibermax cover on.
First I will show you the rough locations of each hole.
Rear
Front
To open up the holes I used a new blade in my utility knife. I recommend putting some soap or other lubricant on the blade to make the cuts smoother. Start at the center of the hole and slowly open it up a little at a time. But make sure the cut pieces are big enough that you use the cut plastic as a spacer. I will get more into this in a minute.
You want your hole to look close to this when done. I kept test fitting as I went.
Once your hole is big enough that the bull ring sits down on top. You want to take your cut pieces of plastic, stack 2 pieces together and super glue them.
Now put a little super glue on one side and stick under the bed rail hole like so.
You want a little spacer like that on all 4 sides. On some sides you will need to use a thinner strip because there is some support. The reason for doing this is, if you don't the bull ring will pull the plastic cover down, leaving a gap in the middle. This makes it so the plastic can't pull down and leaves a clean look.
After this put your bull ring in, make sure it is hooked to the metal pocket. I put a little blue loctite on the threads of the screws to keep them secured. To start the screw you need to pull up on the metal ring.
Also if you want to keep the ring from moving around while driving put a little velcro on them.
phydough
Instructions for installing a bull ring.
Wash your hands thoroughly with antibacterial soap.
Clean the septum. Rubbing alcohol works well.
3
Find the right spot. Feel for the soft, thin spot just below the cartilage and above the beginning of the swell outside of the nose. Mark that spot with a surgical marker. Too low and you can tear the septum all the way through; too high and you will hit the cartilage, which can be extremely painful.
4
Pierce the septum. Take the hollow ended needle and put the tip against the marked spot. Push the needle through the nose, until it is about halfway through.
5
Unscrew the ball off one end of the horseshoe nose ring. Place that end inside the tip of the hollow ended needle.
6
Push the needle all the way through, bringing the ring with it. This will thread the ring through the new hole.
7
Reattach the ball to the nose ring.
8
Care for your new septum piercing. Soak the hole in a saline solution composed of four teaspoons Epsom salt in one gallon of boiled water two to three times a day.
Hope this helps. :crazy:
Fyermanbob
Monrovia Ca.
Warning! Do Not use this type of tie down while offroading! You will either pull out the tie down or tear the side of your bed out! Seen it happen 3 times over the years.
phydough
Have any photos of them not installed, to see how much "bite" they have to the stake hole?
I like the idea, but am a bit concerned of how much real world weight/stress they will take.
linexsa
San Antonio TX
i sell these everyday. my customers tie all kinds of heavy stuff to them. never had any complaints. the only part that worries me is the spacers under the plastic bedrail. i could see that decreasing your capacity just due to the extra leverage.
Fyermanbob
Monrovia Ca.
I've seen them ripped out with bed damage while holding a motorcycle twice and tool boxes/ice chests once. Granted the tool boxes and ice chests were some hard Baja offroading but I'd be very careful just the same!
F
frunko1
Been offroading at the beach with my kayak on top and no issues. wttaiUQ.jpg
