How to decrease charge on 2.5 fox shocks?
DezertRacer
Las Vegas,NV
Any suggestion on where I can buy a nitrogen tank/regulator? Or can i rent one?
Not sure about rent, but you can get them from welding supply stores etc . you will need a regulator that goes to 250, and the fox needle valve is $65+ then you can start . This is why when we charge to rebuild shocks and people say its so easy . its having the proper tools and experience to do it .Everything adds up
mmaterni
Toledo Ohio
This is my refill setup. As previously stated it's not hard it's about having the right tools. Got my tank from my local airgas supplier $90, fox refill needle from Schmidty racing $40 I think it was, regulator capable of over 250psi off amazon for $40 I think. Then you have assorted hose (also capable of over 250psi) clamps, and air fittings to put it all together. I had all that on hand but if you just buy a short hose you can get one for around $30. My airgas supplier will rent a tank and regulator but you will still need the needle, hose, and I highly recommend a lock on style or no loss air chuck.
