How many of you have had to replace the tailgate actuator?
Sonicsunspot
KC
I had this same thing after the recall. Not sure if they just fudged a wiring splice or actually replaced an actuator.
Same issue here. Button on tailgate didn’t work, but it worked with fob at least. I started by replacing the actuator, which was dumb in retrospect because it still worked with the fob. Still no joy.
Eventually took it to dealer who said I had a chaffed wire and spliced it back for $200.
MNRAPTR
Cloquet, MN
Mine works with the key FOB but not the button on the tailgate. Doesn't seem like it would be the actuator when it works fine with the FOB. What would the issue be? Thanks!
Nex
RIP CoronaRaptor
Washington State
Has the TSB been done on your truck for the unintentional tailgate opening?
isis
PA
Did you try hitting the tailgate button twice just like the fob?
Bracamonte
North Texas / Colorado / Black Hills
I’ve noticed that pressure against the tailgate from inside (when loaded up) is too much resistance for the weak actuator. I can hear it click but won’t unlatch and release.
I push-in the tailgate as I hit the release button. This alleviates the pressure on the actuator and gets it to open every time. FWIW…
Sig Fanboy
WV
I have the peasant spec truck. Just has the old fashion ( reliable ) handle. Works everytime
