If you have a Lowrance unit and a radio do you use two different antennae? Where did you mount both?
Typically the Lowrance will have an internal GPS antenna. If you purchase the seperate Point-1 external GPS/Compass antenna, Lowrance recommends you mount it 6 ft away from any transmitting antenna.If you have a Lowrance unit and a radio do you use two different antennae? Where did you mount both?
My radio antennas mounted on the roof by third brake light , and I'm gonna mount my gps antenna on the cowl by windshield wipers like (all the way) mounted his. I sprayed it with plastidip speaking of plastidip of that stuff is awsome . There should be a thread just for it .
John
Sent from my SCH-I535 using Tapatalk
Let me know how the signal is.
