How do you put your truck in park?
JohnyPython
Canada
Well I guess when you do something wrong for many years you get good at it.
I learned something valuable at the Bronco Offroadeo. How to park a vehicle with an auto transmission.
Procedure:
-press the brake to come to a stop
-engage the parking brake
-take foot off of btake
-put transmission in N
-then put in P
I’m doing the from now on. Be kind to your tranny.
pat247
Oklahoma
Procedure:
-then put in P
Good advice, it is very important to set the parking brake before putting into park when on an incline. If you ever have trouble getting the shifter out of the park position this is the reason. The parking pal can break off and let the vehicle roll, not real common but does happen more than one would think. I never thought of shifting into neutral first then into park but that makes a lot of sense.
JohnyPython
JohnyPython
Canada
They said to use this parking procedure all the time even flat surfaces. Might be a bit ocd but saves the parking pawl from getting sheared off.
Could wear out electric parking brakes but keep cable style from seizing.
Procedure:
-then put in P
So... For Jen Too Raptor at least, if you engage the parking brake while in gear, you get REALLY obnoxious chimes and dash warning. I’ve never tried going to N first, then brake, then park but nevertheless, it seems to me that Ford disagrees with Offroadeo.
Also, I’d caution our northern crew about the parking brake. in really low temperatures they will freeze in place. I’ve not had it happen --to me-- but a neighbor did.
CigarPundit
I like wood
Georgia
Didn’t know about the freezing thing.
