How did they paint inside the headlight housing?
FordTechOne
Detroit
They would have had to heat the headlights up to the point that the seal between the housing and lens could be separated, and then try and seal the lens back on. Voids the warranty on the lamps and there’s a good chance that the LEDs were damaged in the process.
Nex
RIP CoronaRaptor
Washington State
They stopped using glue some years ago and basically fused the plastic housing together. I used a die grinder with a cut off wheel on my 2016 F350 headlights to paint the chrome black. I would not recommend it for everyone seeing as it WILL void your warranty for the headlights. And may damage the LEDs as FordTech1 stated.
Grayson
NC
Got me some fancy headlights y'all; going to make up a totally awesome name and put it on the interwebz for all to see.
MurderedOutSVT
Brodozin
The ATL
Wow.....Akins is right up the road from me and Wild willys is the most arrogant, overpriced 4wd shop of pickle puffers in Ga
C
catinthehat85
Socal
Haha ugh not what I was hoping to hear. A part of me wanted to believe you could pull that part of the assembly out from behind like some kind of bulb assembly.
I still think they look good, maybe not good enough for me to tamper with a $$$ set of headlights…thanks all.
Staff online
Members online
93,627
56,935
ID_AZ
