- Joined
- Mar 11, 2011
- Posts
- 1,179
- Reaction score
- 43
Donr get the cutout. Waste of time. And is just loud. No tone to it
There are challenges. It used to be that most muffler shops couldn't bend stainless steel tube, so you had to settle for a system that would slowly rust. I don't know if that's still the case. If you piece togther sections of stainless steel tube in lieu of bending them, then you have a LOT of welds and somthing other than a smooth interior surface.
---------- Post added at 06:29 AM ---------- Previous post was at 06:27 AM ----------
You understand that removal of the resonator will make the truck louder at all times, whether the cut-out is open or not. That might be okay in your neighborhood and it might not bother the police, but then it might. You might also not enjoy the increased noise in the cab during long drives like vacations.
I thought the earlier model scabs had no resonator?
While this is true everything I'm adding is straight on mine and I'm re-using the stock pipes over the axle. I'm also going to TIG it all to minimize any weld on the inside of the pipes.
