Holy cow, these baja S1 are tiny but bright!
Fyatrk
Its on page 287, 288 on this thead:
https://www.fordraptorforum.com/threads/what-did-you-do-to-your-raptor-today-gen2.59415/page-288
The AGM battery is inside the marine case.
Mounted on Builtright panel, using 1.5” spacers, heavy duty galvanized “L” bracket and 2 steel brace that form an “A” . I only use grade 8 bolts.
(basically, everything I put on the bed, is Not permanent and can be taken out, if needed)
The 2 marine solar panels are screwed in using rtv sealant on the bed cover. One goes to the oem start battery, and the other thru the bed hole cover, then to a solar charger connected to the aux battery.
Installed Battery Isolator and added circuit breakers to and from each battery.
(see diagram)
Wow really nice set up
What is that mounting board/rack that is attached to the side of your bed and how did you mount it?
Thanks?
ShadowRaptor
ShadowRaptor
USA
Like what alphatwox already mentioned,
It’s made by Builtright industries.
( you can order, just the 2 large rear panels or all 4 that includes the front smaller ones)
These panels made a huge difference and made my
mods/ mounting my onboard air, jack, gear, etc..possible.
4x4TruckLEDs.com
Crikk
FRF Lady
FRF Lady
Crystal lake il
Yup we do, over in Lindenhurst. Honestly it's setup more as a warehouse but we encourage customers to make an appointment to stop by and browse the warehouse, check out the demo truck.
We thought about opening up a full on retail shop but as you know, this is NOT a 4x4 community here on Long Island so it would honestly be wasted $$ on retail space. So we're 95% warehouse space (5% retail/showroom, although that's becoming storage these days)
In IL?? I didnt know this? Hummmmm
4x4TruckLEDs.com
Ahh you know of Lindenhurst, IL. Different Lindenhurst. We're in Lindenhurst, NY :)
