High mileage owners please check in
Msb.19d
Broadway, NC
I’m about to hit 5k anyday now. Still no problems at all even at this high mileage
---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ----------
Trying not to get to many miles because I want good value when trade it in on the 7.0 v8 raptor in a year an half
mpbowyer
going to hit 100k before the end of January. Anything I need to worry about? Any benefit to swapping trans fluid early?
dixonk
HMFIC
Oklahoma
I’m in same boat. Last month had to put new wheel bearings and axle seals. Now the pinion bearing has gone bad in rear diff so that’s coming apart next week for a rebuild. While I am changing fluid in both diffs, transfer case, and trans. Also flushing radiator, brake, and power steering fluid. Changing spark plugs and changing belt and tensioner as well. Should be a new truck for another 100k. Already did shock rebuilt at 90k.
mpbowyer
Don't be intimidated by the spark plugs, they're not as hard as I thought they would be after reading too much.
dixonk
HMFIC
Oklahoma
It doesn’t look like they are too bad. Autozone had to order 8 more NGK Iridiums for me. I think I will not change the wires. Remarkably Autozone doesn’t have any wires for the truck either.
Deleted member 17706
Guest
I would flush the transmission. All fluids break down after years of use, so it is good insurance. Especially, if you are going to keep the vehicle for a while.
---------- Post added at 10:18 PM ---------- Previous post was at 10:14 PM ----------
Are you going to flush the power steering fluid? Or are you going to pump it out with a hand pump?
I need to do mine, so I have been contemplating what method to use.
Good work staying on top of your maintenance!
waddellw
waddellw
Mississippi
Flush it definitely, mine broke apart before 100k and caused my transmission to mess up, it's worth the money either way as a proactive measure. Also if you wait too long you might as well not do it!
Other than that there are many other small preventative maintenance items that can be taken care of around 100k miles
Sent from my Pixel XL using Tapatalk
RaptorMaryland
Maryland
Can I ask folks to add if the repairs were all covered under warranty or an extended warrenty? I am getting 2018 in 3 months, its on order.
waddellw
waddellw
Mississippi
When warranties are involved it can vary dealer to dealer honestly. But the main idea behind it all is if it's a wearable item that is supposed to degrade overtime then it usually isn't covered. By that I mean brakes, suspension stuff that wears with use. Not so much engine and transmission.
Although my Ford dealer stiffed me on a warranty transmission repair most won't.
Good luck on the '18 I've enjoyed my '13 and '18.
But yeah totally if people want to post what is/is not covered by warranty that adds a new aspect to the thread, good thinking!
RaptorMaryland
Maryland
That works as I am considering buying the extended warranty, but I do notice very little high tech stuff, like computers breaking, which is good.
