I am new to the forum, and this is my first post. I recently bought a 2012 and wanted to upgrade to the factory HID projector lights. I found a pair of oem raptor lights that were pull offs from a truck being retro fitted. They came with a morimoto harness.
I installed them, and they worked fine for a few min, but as I was adjusting the level on the passenger side, that side went out. I turned off the truck, turned them both back on, and then neither of them would turn off when the truck was turned off. I tried the light switch in all the positions.
The grounds were connected to the factory ground terminals on either side of the radiator. I verified all the pin connectors were in good contact and none were bent or broken. Since the lights fire and turn on, I am thinking the morimoto control might be bad. Any thoughts or experiences? The only way to get the lights to turn off is to disconnect the hot wire from the battery. Thanks for your help.
