HID Bulb Replacement Problem
Bozz
Bozz
Royal Smart A$$
Nashville, TN
Before I order new ballasts, how many are there? Just one per side? Or one for highs and one for lows, per side (4 total?)? High beams work, just no low beams.
The Car Stereo Company
here, on frf
each light has a ballast. if your low beams worked on the highbeam ballast, then you have solved the problem. will need 2 ballasts. but verify there is power going to those ballasts first
Bozz
Bozz
Royal Smart A$$
Nashville, TN
Make sure there is power going to the low-beam ballasts? How do I do that? With a multi-tester? The high-beam ones work, so they are obviously (?) getting power.
here, on frf
yes, verify 12v going into the ballast. this will confirm the ballasts are bad
Bozz
Bozz
Royal Smart A$$
Nashville, TN
Got new ballasts in today. Temporarily hooked one up and lights now work. Raining now so will have to install tomorrow. Thanks for the help!
Previous owner had ballasts very loosely zip-tied to the frame. I have screws for the new ones to make a better ground contact.
