Help!!
Ni9mm
Florida
Sounds like you should have kept the original engine. Unless it was more broke.
Bluoval1118
Bluoval1118
Ft. Huachuca, AZ
The original engine broke. Brand new crate engine from Ford. I pulled the old one and installed the new one. Only differences were cam timing sensor connectors and those got swapped
The Car Stereo Company
here, on frf
i believe it will need new programming. so this is the first time it has ever been started/ tried to start? the onboard computers were probably programmed to your old engine. since it is seeing different specs, it might be preventing starting.
