Help!?
F23 raptor
Cincinnati
Hey guys, so I have a 23 raptor with the 801a. Put the triple fog light kit and rigid rear lights on and working fine. Fogs are ran on fog switch, aux 1, aux 2. Wired the rears to aux 3 and nothing... the lights are on with red back lighting when approaching, Truck running and lights kick on when in reverse. I turned the aux 3 switch on and nothing happens. Checked the fuse and it's good, we checked the wire with the switch on and there is no power?
I'm at a loss on where to look and what to try now
Donmatteo
Santa Clarita / Coronado
I think you have it wired to both reverse and your running lights (which you are calling back lighting)
They should only be connected to the reverse lights and the lead going to upfitter 3 or just have them connect to the up fitter only and not into the rear harness.
Turning Blue
Northern Illinois
If I understand correctly, the white comes on in reverse, but not when you flip aux.3. I would double check that you used the correct wire for #3 by flipping the other switches. If it doesn't work, still confirm you have the correct wire, but also check your connection(s).
F
F23 raptor
Cincinnati
Correct, white light comes on in reverse as it's supposed to. Flip on aux 3 switch and nothing happens
