Bhollier
I am checking to see if anyone has had this issue happen to them. I was on my way home from visiting family for Easter, when after driving for 2.5 hrs I get an error message on the display saying "Blind Spot Detection Unavailable", a few seconds later "Collision avoidance malfunction", few seconds later the air bag light starts flashing. During this time the radio does not let you change or control any of the functions. The A/C also turns off and the blower is just blowing on low speed outside air, front windows won't roll down, door locks won't operate. Truck stays running fine with no power train issues. I continued on my way home and about 10 min later everything resets and goes back to normal. Did this one more time about an hour later and reset the same as before. Once I arrived home I pulled up my codes on my tuner and the only thing listed was a communications error.
I have driven the truck today for about an hour or two 75 miles in Houston traffic with no issues after I cleaned all the sensors and checked the fuses/ connections. I can't seem to figure out why this happened or what the cause is. The only thing I have noticed recently is my nGauge cycles power often. Truck will be in the shop in about a week for work and will have that addressed then.
I have never had any issues with the truck other than this, even with all the mods I have. When I have the truck in the shop we plan on reflashing everything just in case there is a gremlin hiding.
Trying to get any thoughts on what else might be going on here or if anyone has had anything like this.
