Help w/selecting correct radio equipment
Wilson
South Dakota
First time you can borrow a hand held but for bigger ones is where I'm recommending the tyt, I did the cheep rough first ended up getting the tyt so do it right the first time will actualy save you money.
Ditchplains1
Trescott, ME
Rob in CA,
Make sure the antenna is a NMO mount. You have picked a lip mount NMO antenna base. Unless I misread the antenna you picked said 'non NMO mount'....
Eddie
Wilson
South Dakota
Also borrowing one the first time you can listen to what ones you like check them out that's what it's all about. Have fun
Rob in CA
Rob in CA
North Carolina
Thats good advice. That's why I figured I might as well go all the way with this, so I won't have to do it again down the road.
Rob in CA,
Eddie
Hmm, I looked at the Antenna from the link I posted and under mount type it says "Order separately from NMO style mounts". Maybe I'm missing something? Wouldn't be the first time lol.
cbcgeneral
Southeast Pennsylvania
I actually PM'd him a few days ago. I think he may be busy with snoball though. I'm debating whether to wait for him, or just order off amazon.
Contact him through LVJ Motorsports.com and @Kmandoske will usually answer right away plus you can just place the order right on his site. He just sent me a radio last week so he's still available to sell stuff.
Rookie
Fort Wayne, IN
The antenna is NMO. The combination will work barring you don't need more than that 6.5'
Click here to donate $5 for a chance to win $500 worth of Rogue Racing goodies!
freedommotorsports.us
Email: [email protected]
Rob in CA
Rob in CA
North Carolina
Thanks for the info!
---------- Post added at 09:44 AM ---------- Previous post was at 09:43 AM ----------
Ok good. Glad I wasn't misunderstanding what it was saying. Thanks!
ajstar89
Newport Beach CA
Go to pci and get a 50 watt, do the magnetic mount and try it out and see how you use it. I put mine below the glove box. I use to just screw in the antenna and run it between the seats to the back and out the door jam worked perfect every time. I would take it out after the runs and nobody could tell. I like mine so much I committed to the roof mount. But to each their own.
Rob in CA
Rob in CA
North Carolina
PCI? Not familiar with them. You bring up something I've been going back and fourth with though, which is how permanent do I want it to do be. I would only use it during runs, so I'm kind of leaning towards having it be easily removable like you're talking about.
Edit: Found PCI after a quick Google search.
Edit x2: I'm digging there chase packages. Makes it easy. Thanks for the tip!
cbcgeneral
No problem bro. Keith is a good dude I've bought a few things from him. Plus if you have any questions or need help with any problems while you're installing it he has no problem helping you over the phone. You don't get that kind of service when you just order something online.
