This week I plan on wiring up my new off road lights. I have a set of 4 lights I want to wire them up two of the switches.
is there a post describing the wiring diagram and how to do this?
I was thinking I would use Aux 1 and Aux 2... What are the fuse sizes of these two switches" are aux 3 and 4 different?
any help would be appreciated..
thanks
Aux 1 and 2 are 30 amps, Aux 3 is 15 amps and Aux 4 is 10 amps.
To hook the things up, you first have to spice the wires together behind the clove box. Remove or drop down the glove box door and remove the triangle shaped side panel by (I love this part) stick your finger in the round hole, curl it up, and pull!!!
The wires are about 6 inches too short, but you should be able to pull them out the door side just enough to get the strippers on them. You will need mechanical strippers, there is not enough room for using your teeth or a pocket knife, so don't even try. There is also not enough room for a butt splice and don't be a jerk and use a wire nut, so plan on twisting and soldering. The color codes are in the video.
Under the hood on the passenger side are the pass-thru wires. Hook them up to whatever you like. The color codes are also in the video. Or you can just connect to one and be surprised!!!!
You may want to change out the fuses from the stock size to a smaller one, appropriate for your use.
Here is the video - this guy goes thru the glove box and i had better luck going thru the side panel. I suppose if you have little hands and like to stand on your head, the glove box route is OK.
YouTube - PASS THROUGH WIRES
