hello from chicago
drc2013
drc2013
chicago
Wow @CoronaRaptor Your truck looks dope. I've never seen that many photos of it. What type of lights are those?
all my lights are Zroads if you get the roof lights and have them installed or do it yourself do not follow the directions that Zroads says to use a cutting wheel to make a square opening on the inside structional cage of the roof i used a step drill bit went thru about 6 of them but it was well worth it no unsightly square cutout in the structure use the step drill bit to make a hole wide enough to get a thin wall socket in to tighten the nut down for the roof bracket. then your good to go just take your time lower the headliner down make sure you dont bend it that crease will never come out
Donovan
DC
To be fair, I’d still be worried about leaks.
