Hella 4000 HID- ballast mounts?
Conejoracer
Conejo Valley, California
I picked up some used Hella 4000 HID's today. These are the external ballast models. I've looked using google for ballast mounts, but found nothing. There must be something better than zip ties!
KTM RAPTOR
Ontario, Canada
If you want a cheap alternative you can use metal hanger strapping found at local hardware stores. I've used this in the past using foam tape in between the ballast and metal strapping.
Just an idea.
Danactive
I'm Back!
Syracuse, NY
check out my build thread, i made a box out of a thin sheet of sheet metal and mounted it behind my skid plate...
