Headlight upgrades
gbrown27
Auburn, Al
I have the recon projector headlights and the light output is awful. I could not see my lights in the rain and i almost wrecked a couple of times so what should i do for low and high beams? and where should i order from
Low: HID or XENON
High: 35 or 55 W HID
Humvee21
I'm sorry to say this, but first of all... throw away those god awful recon projectors. Now, either do a bi-xenon HID kit in the factory housings, contact Ducati for a retrofit, or get the 2013 headlights.
Yukon Joe
Trafford, PA
I think hoss has a wire set up for the 2013's.
I'm digging the Ducati retrofits.
Joe
Big Blue
Administrator
Staff member
Admin
USA
^^^^ This.
HID converstion kit, around $125 installed. 100% more light and its white, not yellow.
Humvee21
How much do the bi-xenon projector run for?
Ducati's projector retrofits are somewhere around $700 if you send him your housings.
If you want to go the cheaper route like Big Blue and I did, you will not have "projectors." All you will have is a HID plug-n-play kit installed in your stock housings. What this means is that they are basically just brighter bulbs inside your housings. You can find these for about $70-250. If you want the kit, PM me. I have considered selling my kit since I am tired of the Auto feature. I remember you are in GA, and so am I. I can even help you install them if you need.
Spider-One
NT, Canada
Downside of the cheaper kits is the light is nowhere near as well distributed as a projector. They also produce glare due to the reflector being designed for a halogen bulb vs xenon bulb. Most say glare isn't too bad in our stock housings but I'm waiting to go to a proper projector.
