Hard Tonneau Cover Options
IRONMAN
Well-Known Member
MICHIGAN
What issues are you encountering when using the A.R.E. LSX? Does it become misaligned?
When off-roading with it on it opens up quite a bit and yes it does shift around.
Not good for off-roading at all.
But I still love the look of it.
JJ f150harley
Traverse City MI
Any cover like the ARE or any comparable fiberglass ones will be horrible off road but that said anytime u go hard ull have to readjust it.
Sent from my DROID RAZR HD using Tapatalk
2004boss
metro detroit
No it comes with a white led bed light on the left of the box. I wired my lights in and unhooked the white light. Everything works off of the remote fob it comes with. The raptor cut out is the recon door sill. it sucked as a door sill but works well as a bed light
Sent from my SCH-I535 using Tapatalk
JBH
Helena, AL
I had an Undercover SE for 2 years on my Lariat before I ordered my Raptor. I cannot say how it would perform off road but I can say it is very durable and well built. I think the ABS would hold up better than fiberglass and when I shopped them against each other it is much lighter but can hold more weight if you want to put something on top of it. The only downside I would run in to is it has strengthening ribs molded in to the underside that protrude down in to the box about 2 inches so you do loose some bed height.
If you were trying to haul something that is right at bed height the top won't latch.
