Dash Z Lighting Part 2
Called up the Mfg. Turns out my order was incomplete. HID is coming as a kit separately from Fedex. Not to happy about the poor communication as I expected the unit to ship complete and pre-installed.
Instant Gratification - thats what I wanted.
Here is an HID Installation video that dash links to:
Install HID Conversion Kit - YouTube
Turns out what I have on the unit so far is an H7 in the "Halogen" style projector. So I should see a huge improvement over what I have now. The good news is that the cut-offs are very sharp, just needs more HP.
Oh, Matt, I did find out that these specific ones are made for Dash Z by CG Mfg. They claim no relation to Recons or Spyders. Also open two spaces that look like they were designed for LEDs are empty by design.
Here are some pics from this morning and (Abby's 8th Grade Promotion)
Dash Z Headlights - Part 3 – HID Kit Install – Post 1
Got the package yesterday, waited till 4:00 in afternoon and ripped into it at work.
![DSC02334.jpg DSC02334.jpg](https://www.fordraptorforum.com/data/attachments/181/181767-d3711e3a5119cc566eb32b7952f70c20.jpg)
Looking at the wiring, I was confused at first how it was going to work with the raw connections on the inside of the seal.
Removed headlight, as I found out, the connections and the bulb locations are completely separate. All the wiring connections are inside the housing. Large rubber caps seal both the projector low beams and the Halogen High Beams.
The instructions alone are almost worth the cost of the kit. The transliterations are very funny. “be careful to not mis-connect reversedly”.
Unfortunately they are for multiple types of installations, some of which require separate relays. The H-7 kit does not and also does not require any direct connections to battery or ground.
The wiring is very straight forward.
Remove cap over the projector low beams, undo wire hold clip, remove H-7 bulb and remove connector from back of bulb. Be careful to not touch glass on this or new one, set aside old bulb. Remove wire connector from old harness by inserting flat blade screwdriver to release clip on brass connector as pictured.
I found some extra strands on the oem harness needed to be cleaned up. I wrapped in some electrical tape on the sharp side and slipped some shrink tubing over the connectors before connecting to new harness. Black to black, Blue to Red. Made the connections, shrunk the tubing.
Next step is to cut 25 mm round hole in back of rubber cap. I used the packing washer from the new bulb as a template, it was pretty close at 27 mm, so I drew thick black line using sharpie and cut to inside (smaller) with razor blade (no exacto knife at work.)
As you can see I hacked it up pretty good, but it works fine and irregular cuts are completely hidden under rubber grommet. Re-install cap, I moved inside wires to side so nothing is pressing on inside of grommet.
Note: While it was on the bench, I had a good opportunity to examine construction in good detail. The lights themselves are well sealed, sticky "flowed silicone" is abundant around entire perimeter seal, all connections are watertight and are designed to be fairly idiot proof. I did notice a vent cover that I believe is for evaporation of any water vapor and heat expansion/ breathing, the angled rubber breathing tube protects against water back splashing.
![DSC02340.jpg DSC02340.jpg](https://www.fordraptorforum.com/data/attachments/181/181775-0314b9dc41bb26209266449175c6d0fe.jpg)
I believe it would need to be submerged for some time for water to penetrate.
I do have
concerns about dust getting thru this opening and decided to add a cloth filter.
![DSC02347.jpg DSC02347.jpg](https://www.fordraptorforum.com/data/attachments/181/181777-810e76ab49208a8bbe53a56d89baa08a.jpg)
The first one I simply slipped the cloth between the rubber and plastic, the second one I zipped tied down as it seemed like it might vibrate off. After sleeping on it, I am going to remove both lights again and try and come up with a more effective dust shield. I am now thinking that dust will simply go thru a single layer of cloth. I am also going to JB weld the metal side clips on one unit as they will no longer stay in place (Installation boo boo)
Before installing the light housings, I decided to install the Ballasts to the cross frame member. A couple of self taping metal crews made for short work. The right side needed to be angled due to rubber shield connected there.
![DSC02349.jpg DSC02349.jpg](https://www.fordraptorforum.com/data/attachments/181/181779-8a0dcf999b17e9500426cad473c15be2.jpg)
Connected ballasts to housing, installed ballast into bracket, reconnected oem harness – 3 connections, tested and then bolted back in.
Repeated for other side.
Installation complications:
I had issue on turn signal oem connector, would not release at connector so I simply remove entire bulb with connector on that one, no big deal.
Bent a pin on the parking light connector, same one that I had trouble with in Part 1, fixed the bent pin, but then it didn’t work, had to remove and redo that pos connector that I had used some shrink tubing on, must have pulled it loose while fixing the bent pin, anyway, it is fixed and working well.
Tried to take some of the same set up pictures as I did on the first install. Due to late hour, I tried to do
without tri-pod, wrong, 1 second exposure hand held = blurry pictures.
Then camera battery died, so sorry, only a couple pics worthy of showing.
Impressions so far:
I really like the lights, both the looks and performance. HID installation was a lot simpler than others. Instructions sucked other than the humor factor, but you have mine above so don’t let that effect your decision. Price is right. Cutoff is outstanding. There is a small gap in the middle where the two light streams do not connect which is odd. They need to improve the parking light connector to the oem harness. It would be nice if they provided dust filter for vent tube.
Finally, I would love to find a way to have “Daytime Running Lights”, I saw when researching that some believed the dealer could program (did I ever mention how much I loath taking my vehicle to a dealer?), I am also going to ask Mike at 5 Star.
