GROUP BUY: SS Braided brake lines
IRONMAN
MICHIGAN
What is the advantage of getting the +2 length?
Exactly what everyone else has said, gives you that extra peace of mind when at full droop especially with 3.0's
If you have or will do mid perch are the extended length needed?
Not necessary but you could always do +1 just in case, plus it doesn't cost any extra.
FIRST POST HAS BEEN UPDATED WITH NAMES AND INFO..
Scrap man
Ohio
Hey guys if you have a later model year you can buy the earlier year kit and make it work on the later year that is what I did. The only difference is the hose the links the rear caliper to the axle the factory is rubber I can't remember but you may have to flair the line that's it it's a good upgrade.
