it happened when i put in the morimoto headlightsDid you fid a solution, I'm having the same issue?THX
Oke, gonna try this. Thxit happened when i put in the morimoto headlights
basically whenever the current is off from what it should be. the BCM will fault and turn off parking and grill lights.
Need to reset the BCM code to clear it out. what usually works is turning my light switch from auto to off and back a few times to get it back on.
Thanks for that info. My fault went away after i turned i switched my turn signals from sequential to solid. But i will keep this in mind if my BCM DTC comes backThis is partially correct. However, resetting the BCM DTCs is only a temporary fix. If the current draw varies from factory, the BCM will continue to set the DTCs. After a predetermined number of faults, the BCM will enter a failure mode and set DTC U3000:49, at which point it must be replaced.
The BCM will have DTCs in it for the circuit fault. You may be able to clear them to reset it, but if the fault has occurred too many times it may permanently disable the circuit.Hmm. Same issue here. Tried the switching back and forth of lights from off to auto but no luck. Did you do this with the car off? Ignition on ? Motor running ?
Also removed the sequential function of the Morimoto lights but no dice there either.
You will need IDS (Ford dealer scan tool) or ForScan. ForScan is available for free online, you just need a tool like OBD link to connect to the vehicle.Thank you for the reply!
Is there anyway to read the errors to be 100% ? I didn’t have anything come up on the Cobb handheld.
