Got my Airraid today
Mjolnir
Mjolnir
Colleyville, Texas
The in-cab noise is nothing more than a little intake honk at the shift points. If you're not into the pedal, it's not obtrusive. If you are on the gas, it's damned impressive. But if it bothers you, you can put the unused rubber edge gasket all the way around the top of the airbox extension. That quiets it a bit.
The prefilter is a good idea. I bought one, and cleaned it yesterday for the first time. It was loaded with pollen, but the pleated filter itself was still clean. See photo.
Also, you will be surprised if you ever pop the hood and feel how warm the intake tube is after a drive. Hot air is not dense air. I found a good, easy, and inexpensive solution. See photo.
I'm getting the pre filter. the tape is not a bad idea, that might be next. wonder if I can find it in black. (although that might defeat the purpose.)
