GEN 2 Good source of ground, +12v and switched +12V as well as boost for gauge?
xrocket21
Maine
Like the title says, does anyone know a good source to pull ground, +12v and switched +12v for a boost gauge install. I remember on my '11 ecoboost, there were a lot of one-way valves that made it tough to find a spot with both boost and vac.
Thanks! The 801a package does not include a boost gauge.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Sorry to go off topic but I can't help cause I won't have a truck till next week but does the 801 come with a fuel range in the menu?
xxaarraa
Southlake, TX
xrocket21
xrocket21
Maine
I ended up getting +12v from the purple/green wire on the left side of the column, Ill from the pedal adjustment switch, and grounded to a bolt by the e-brake. Tapped the boost line in pretty much the only location of a small, soft line.
BigRedRuf
You can just change your settings to always show digital boost gauge....?
Sent from my SM-G920V using Tapatalk
xrocket21
xrocket21
Maine
This is where I tapped for boost. it is pretty ugly, but Ill clean it up at some point, it is tough because you have to use a few adapters to neck down so small. I also left it long in case I need to re-route anything after I install the AFE intake.
