GLRE: The Offical 2016 SnoBall thread
Kanakry
Kanakry
Great Lakes Region
Yes I am registered and will be Representing for FL once more. Its only 23hrs of driving straight thru each way. But I might bring the truck up to MD in December again, this time to have Glass fenders and Bed Sides installed prior to Snoball. This will make it a shorter leg and then go up a day early and have Josh wrap the truck before meeting up with the Convoy along the way.
So if everything Pans out with the custom wrap design and glass deal the truck will be making its debut at snoball of the transformation
It won't be the only one. :artist1:
mobob
I'm in!!!! Now the questions start......
On the rear facing ambers: One small lightbar or two smaller cubes?
Anyone driving up from the Missouri?
SilentShooter
Siesta Key, FL
The higher up the better.. Bar or cubes are fine, but with bar you might need a dimable one for use at night cause if its too bright that will blind the drivers behind you from seeing tail lights.
mobob
Ofallon, Mo
We are tentatively planning on heading north on Thursday night and staying in northern IL (Rockford I thnk) then running the last 400ish miles on Friday. I am open to options on grouping up, especially if the weather sucks, which I am expecting.
DocSpooK
TechsAzz
two little ones better as we can judge distance, can't do that with one.
Coming from Kansas, we should join up with the Chicago convoy, did it last year!
