GJ Third Brake Lights in stock!
OffroadAlliance.com
Boston, MA
We have a few of the standard and NMO antenna mount third brake lights from GJ Motorsports in stock and ready to ship! Shoot me a PM or comment below to get yours ordered today while supplies last.
Details​
  • Optional NMO Antenna Mount​
  • CNC Machined from billet 6061 Aluminum​
  • Uses factory bolt holes​
  • Integrated gasket to seal the light enclosure to the cab​
  • Plug and play integration with the factory wiring for brake, marker and cargo lights​
  • Wiring harness included as standard​
  • No drill installation, uses factory mounting holes​
  • Three 1W Red LED marker and brake lights​
NOTE: This housing is for trucks with the cargo camera in the 3rd brake light, if you do not have a camera you need the 2015+ housing.
NMO Antenna Mount​
The NMO Antenna Mount option adds a standard brass NMO antenna mount to the top of the housing, The mount includes 17 ft. of RG58 cable terminated with a PL-269 connector ready to plug straight into your radio.
We recommend the following antenna and cap for the NMO mount:
  • Browning BR-158-S 150-170 MHz VHF NMO Antenna​
  • Larsen Plastic Rain Cap for NMO Antenna - Black​
Please Note: The base of the antenna mount is not powder coated, it is raw brass.
Wiring Harness Options​
All wiring harnesses are cut to length and pre-terminated with weatherpack connectors and wrapped in soft loom for easy installation in your truck. The factory integration for the marker lights and cargo light uses the factory connector and does not require any cutting or soldering.
BASIC HARNESS: This harness provides integration of the 3 marker/brake light LED's with factory wiring harness as well as connecting the center light to the cargo light circuit. Two additional circuits are provided to connect the outer lights to the factory upfitter switches in the passenger kick panel.
REVERSE LIGHT HARNESS: This harness has all the features of the basic harness, but also connects the center light to the brake light circuit so that it comes on automatically when the truck is placed in reverse.
STOP/TAIL/TURN HARNESS: This harness includes a stop/tail/turn controller to integrate the outer to lights with the factory brake/turn signals. It includes inputs for connecting to your aux switches for:
  • Master power to turn the system on/off​
  • Strobe Function​
  • Strobe pattern change (momentary switch to be optionally mounted in the dash)​
  • Constant on override to disable the turn/brake integration​
2-WAY Y-SPLITTER: This allows you to connect two lights to the same aux switch with a pre-terminated Y cable. This cable is terminated with weatherpack connectors and is plug and play.
3-WAY Y-SPLITTER: This allows you to connect three lights to the same aux switch with a pre-terminated Y cable. This cable is terminated with weatherpack connectors and is plug and play.
BryBlanch
Gilroy California
Gj Motorsports makes a solid product but has the worst and I mean the worst customer service ever. Still haven't received products I ordered since 2021 black friday. Won't return voicemail or email.
