GJ Motorsports 3rd Brakelight
Clockton
Northern CA.
Work/Scene is best for camp lighting, bed lighting, or just lighting up the general work area. This is ideal when mounted up high and aiming down on an area.
Wide Cornering is ideal for backup applications when mounted lower on the vehicle (bumper height).
Here is one S2 Pro, Work/Scene
www.bajadesigns.com
So go for the work scene white in the middle and two amber spots on the sides for dust?
zombiekiller
OG BooBooRunner
New Orleans
I wouldnt go spot for dust. Driving/combo or wide cornering.
At night, amber spot chase lights can be pretty dangerous to the driver approaching your rear.
Jimbo
Mad Frog Mattis
IL
Then they should back-off.... so seems like spot would be most beneficial.
zombiekiller
OG BooBooRunner
New Orleans
But if your spot blows out their night vision and they take a header into an inanimate object because of it, you're now a real *******.
You can see the wide/cornering or driving lights just fine from a good distance away.
If you're worried, add a flasher to your chase lights. It will draw more attention than burning their eyes out.
If anyone is coming up on you THAT fast that you'd need the distance that spots produce, you're on the wrong freaking route and getting run down by trophy trucks.
Jimbo
Mad Frog Mattis
IL
They're beneficial. I had guys in NV comment on how great it was to know someone was ahead of them through the dust.
As for someone flying up on you, you haven't been on a run with @mnblly yet, have you?
RC51TOFUMAN
in Thee OC
I am interested in this. Looks great. Would the seal/ gasket be alot better than the Ford OEM?
I had to replace mine 2x under warranty due to water damage
Sent from my SM-G950U using Tapatalk
Baja Designs
The Spot pattern will get the most attention but be careful at night running two S2 Pros in Spot. They are very powerful! I personally like the Amber Driving/Combo. Here is just one S2 Pro, Amber Spot cutting through the dust.
Deleted member 12951
Guest
I am putting a clear work scene in the middle. On the right and left, I am going with driving/combo ambers and the one on the left, I will be flipping the lens. In my opinion, you want the spot part of the combo facing the rear directly and the wide part of the lens on the farthest outside edge on each side. I have seen where spots are used and you cannot see it from the side if the truck is turned slightly sideways. Having the wide on the far ends should help being seen from an angle. I am going with all S2 Pros.
zombiekiller
OG BooBooRunner
New Orleans
i have not been out on a run with mnbily...
BUT, If y'all want to invite me to come run, I'll happily switch my squadron lenses out for spot to be safe. :biggrin:
copb8
Highland Village (Dallas) TX
Looks like an awesome unit and definitely being considered.
How many screws mount these to the cab? Are they upgraded from the stock lense mounting screws? I'm concerned about the extra weight and size of the unit and whether it will hold up to being jarred around or if a car wash brush will damage it?
Sent from my SM-G955U using Tapatalk
Staff online
96,364
60,273
NTXRaptor
