Giant motorsports ddl kit install
ntm
ntm
Alberta, Canada
Still no bedsides, but the mechanical stuff is wrapped up.
Had to weld square tubing along the top inner edge of the bed structure to keep it from self destructing while offroading. It'll give something for the glass to bolt up solid to as well.
The front end now is pretty stressed to keep up with the rear end, I may have to put the 4wd uprights back on to allow more up travel from ride height. There's about a 4" difference in the vertical position of the wheel hub relative to the lca between the 4wd and 2wd upright.
lexmotorsports goodguy
@ntm truck looks great.
Kudos to you for stepping up to the one of the 1st. I have talked to Geoff about this kit a few times. He has done his homework on it, I think you did a great job on the driveway install and look forward to seeing some continued feedback from you about the DDl kit.
