General Grabber Red Letter in the Snow?
6.2
Banned
Canada
i cant imagine grabbers being good at all in snow.
at2's will be much better in snow than the grabbers.
just look at the treads on each tire.
at2
grabber
much more siping on the at2. will be a lot better in wintery conditions.
now, when it comes to strictly deep snow, i cant say, but light snow and ice, at2 hands down between your two options.
a siped red letter will be a good option as well imo.
BlueSVT
San Dimas, CA
I've had them in snow... They were ok, once aired down to 18psi or so! I tried 25 first, and it was still having a hard time getting traction, 18 was much better! Keep in mind, this was only 6-8" of snow, not 1-2 feet of it.
The large wide pads on the grabbers are NOT good for wet/icy traction... But they work alright I suppose! Of course, an A/T tire like the BFGs will likely work much better...
BIRDMAN
Birdministrator
Boston
Oh my God ...stop recommending red letters for snow. They are the total opposite of what a good snow tire should be.
Sent from my thumbs using Tapatalk 2
Allied Offroad
Kansas City
You guys mean General Grabber Pink Letters right?
I did not like the Grabbers in any condition, however the only condition i never tried them in was loose rock/dirt, which i have heard they excel in.
BigJ
Well crap, now you guys are freaking me out. We're headed up to Tahoe in a couple weekends, and I don't plan to do any offroading, but the roads will definitely have snow on 'em. Am I gonna be iceskating all over town??
6.2
Banned
Canada
Yup.
Throw weight in the back for sure and go easy on the skinny pedal.
BIRDMAN
Birdministrator
Boston
The Raptor will muscle its way through most situations with 4wd, ground clearance and horsepower. I've said it before, the Grabbers will get you where you need to go for the reasons stated above, but if the question is a good winter conditions tire, the Grabber is not the answer.
I got severely stuck in packed snow ruts 2 winters ago. I wasn't high centered, I was just sitting in a rut. I would let off the brake and the tires started spinning in place with little or no throttle input. That was with the stock BFGs. If you're going in a straight line in loose packed snow, great. If it's time to corner, brake or make an evasive maneuver, that 6000lb hunk of metal has a lot of momentum to rely on tires/rubber designed for hot temps and sandy conditions.
BluSVT said he had to air down to 18PSI, that's what it took to get the Grabbers to flatten out, curl under and ride on the shoulder for additional side to side stability. That nowhere close to a long term solution but pretty much tells the story.
Without any technical data to back up my general instincts, I think all of what I said is a pretty fair assessment. Lots of weight in the bed, corner early, corner slow and slowly accelerate through the apex of a turn so your front tires via 4wd is pulling you through the turn. If shit gets ugly, turn in the direction you want to go and hammer on it, standing on the brakes is the worst thing you can do.
---------- Post added at 09:48 PM ---------- Previous post was at 09:41 PM ----------
and FWIW...
Straight from General. You don't have to take my word for it.
GENERAL TIRE said:
While Off-Road Maximum Traction tires are branded with the M+S symbol and able to churn through deep snow, their typical oversize applications and the absence of snow-biting sipes in their large smooth lugs can challenge their on-road wintertime traction on packed snow and icy surfaces.
jdowens1
Ford Senior Master Technician
Montana
General grabbers have there place but I wouldn't run them in areas with a lot of snow. They will be fine for a trip or two though. Like bird said the momentum helps a lot. I see more people stuck with very aggressive treads like grabbers or mud terrains and its been my stick BFG that's pulled them out.
95,983
59,706
onthony
