Gen3 2024 - Dynamic Bending Headlights
ksjrb03
Not to make this even more confusing, but my 2024 headlights do bend when I turn; I've noticed at slow speeds, and gradual turns on windy roads.
Not quite the same light drama as my wife's BMW, but it is noticeable.
Thanks for the info. Would you mind checking if you have the option in your sync menu?
settings -> vehicle -> lighting -> adaptive headlights. Only option I can find in that menu is auto high beams.
Andrewalker7
There are five (5) options under lighting, in this destination:
Auto High Beam (toggle)
Daytime Running Lamps (toggle)
Welcome Lighting (toggle)
Autolamp Delay (menu)
Zone Lighting (menu)
RaptorND
illinois
Any more info on this ? I went from a 22 to 25. Def doesn’t bend like the 22 when turning the steering wheel. When though the window sticker says it has it. I do notice the lights don’t dance on startup in auto mode but do when you switch to on.
Stevdug
I have a 22, I'm working on converting to 24 lights and grill. To test if the 24 light would function at all in the 22, i pulled the grill and stuck a 24 light on the pass side with the 22 still in driver side (using the module/ballast from the 22 on the new light) and both the 22 and 24 danced together on start up and moved in perfect sequence while driving
CancerDoc22
Arizona
Mine do bend with turning on my ‘24. More noticeable at lower speeds like in my neighborhood, haven’t noticed on freeways but am taking a long distance trip soon so I’ll get a better sense then
MDJAK
NY
I had the fore-skin done both on my unit over 60 years ago and on my 22 Raptor and enabled the glare free lighting. Glad I did both, though the former caused me to lose my best 8". I just picked up a 25 and expected to see glare free as an option as it's been legal in the US, soon to be mob boss of canada and greenland.
Hope that can be enabled by forescan.
