Gen2 Winching & Recovery Options
sixshooter_45
Arnold
Yeah, I'm trying to figure out best way to go with a winch/ intercooler setup.
Bob Davis
St Louis, MO
I'm a new member...2020 Magnetic on order...First post
In my research, I came across this...$319 . Using pulleys it can pull 8,000 pounds. Only weighs 41 pounds. "Winch-in-a-box". No idea if it would work well....but might surprise us. I don't want to get stuck when out alone.
My preference is SWARFWORKS...keeping factory bumper...but have yet to find out if replacing the intercooler with a COBB STAGE 2 will VOID the warranty....an important issue. So I might end up with a Winch-in-a-Box.
Thanks to everyone's help, so far.
Bob D
former Jeep-H1 Hummer-Maverick X3 owner
jabroni619
Here's my setup. This was just me testing it, i've since added a quick disconnect connector to the winch and back of the truck. Like someone else said, it's heavy, but it's not too big of a deal to put in in the bed when I plan on doing some off road. A front mount would be ideal, but I really didn't want to deal with having to buy a new IC and relocate it. This combine with a pair of max traxx should be able to get me out of any jams I find myself in, or help others get out of.
jabroni619
AH, and here's a photo of the connector. I didn't think I had a photo of this in my previous post.
REMIX
REMIX
Sarasota & Jacksonville, FL
That Harbor Freight winch has a ton of good reviews, and is what I was considering until I discovered you cannot get to the clutch lever with the factory bumper and Swarfworks mount. And that system requires a winch that is 6x more expensive LOL. Plus ANYTHING restricting airflow to the AC condenser is very worrisome. Don't want to spend $3,000+ to find out my AC doesn't work when I need it to in 100% humidity and 100 degree temps.
But $200 for a Warn connection kit to the battery? That's almost as much as the winch in the photo above.
Do you have a parts list for building a battery connection kit, or is that the Warn one?
jimmyjamm
Bend, OR
I have the Buckstop Classic with pre-runner grill guard with a Warn 9.5XP (actually the one pictured on the Buckstop webpage, mine was used to desing the bumper). It is only listed at 105 lbs over stock, without the grill guard only 75 lbs. over stock; mainly because the bumper is made of 1/4" aluminum instead of steel. The weigh is only noticeable in that it causes about 1/2" of front sag, but without any reduced approach angle I haven't had any off-road clearance issues, and the piece of mind with the winch (got stuck before the bumper/winch were mounted and had to be pulled by off-road dumptruck) is great.
Also, this opened up more airflow to the stock intercooler location, makes for a win-win!
jimmyjamm
Bend, OR
dewalt
A half inch dyneema bridle onto front hooks with soft shackles wouldn't add any weight and give you a front pull option
As well. Dyneema would reduce winch weight if you replaced cable
jabroni619
X-Haibei Pair 350 Amp 2/0 Gauge Battery Quick Connector Gray, Jumper Cables Connect Disconnect Plug with Waterproof Caps for Trailer https://www.amazon.com/dp/B00L04A78U/?tag=fordraptorforum-20
SoundBox Connected 0 Gauge Red/Black Amplifier Power/Ground Wire Set, 50 Ft. Cables https://www.amazon.com/dp/B017VBMHRO/?tag=fordraptorforum-20
That’s what I got.you may also need a crimp tool.
Hammer Battery Lug Crimping Tool for 8, 6, 4, 2, 1/0, 2/0 American Wire Gauge (AWG) Wire and Cable https://www.amazon.com/dp/B07DBQZPNJ/?tag=fordraptorforum-20
