Gen2 features missing from the Gen3
Antho
Making the below forscan changes in the SCCM will make the LH switch not work. You need to new switch prior to making the change.
Part number i was given is ML3Z-9c888-AC
Its not even available yet but my dealership parts guy verified its the part number for 2022 LH
The forscan changes that i found are below. You have to go to the "Raptor Status" page to see the option to save mode
SCCM---724-03-01 x4xx-xxxx-xx (LH switch config)
IPC------720-11-02 8xxxx-xx (Enables My Modes)
@briguyraptor @Azholley
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Thank you sir!!
Littlefx4
As always, you’re on top of it man. BIG THANKS for putting this out there!
thatJeepguy
GA
If a 5.0 was in a raptor what kind of milage would it get?
PandaBoi
Dallas, Texas
@Antho have you found out how to add the current gear number like on the Gen 2? I would assume it could be possible since it shows up but only when tapping the paddles or in manual mode.
EDIT: looks like i might have found something here, continuous gear display, i might take a look at this once i get home later tonight...
