Gen 3 & R Front Differentials Grenading
Dnpbakon
jacksonville, Florida
maybe another reason for no torsen diff...
or maybe it makes it worse with one wheel overspeeding in the air and when landing boom goes the diff...
is this a housing, or differential failure??
This could be a valid point.
I’d also point out the one I saw explode last weekend was a 23. So no torsion. Not sure if that would make a difference as I also saw a 22 with the same failure.
TomDirt
Hesperia CA
Are the Torsen units in newer trucks the same design as older versions? Because the older Torsen units have been added to many thousands of regular f150 trucks for over a decade, and I've never heard of them having a high failure rate.
shigman
Cypress, TX
I had a housing failure on mine, the internals swapped right into a new case no problem.
MDJAK
NY
As opposed to, say, the ‘baja’ course the set up ? not for nothing, but the trucks are locked in 4h baja at 50-70 mph over terrain that would tear a street vehicle in two.
I’m not disagreeing with you btw, just I’d like to understand how we’re significantly different in the various use cases.
Having done Assault, IMHO, there’s only one reason they tell you no 4wd and it’s because the takeoff is short and they don’t want you to pick up speed. The so-called jump was the weakest part of the day.
downforce137
In Diana
I believe the housing may have changed with gen3, but the gen2 diff housing goes all the way back to 2009...
Although I didn't go back and look again after I fixed my broken housing.. it seemed like the part number was up to 2020
edit 2022-2023 share the same part number, and 2011-2021 uses the same part number housing..
I’m just sayin’... I can get some pretty decent air at the 1604 / old sulphur springs road interchange, and that’s from a dead stop. Some day, if I ever make that light, I’ll post the video.
Littlefx4
I just might set out and explore that area Smurf...see this jump you talk'en bout. lol
tm965
NOVA
i think its that and the expectation that some over enthusiastic short bus drivers wont take their foot off the gas midair
