Yes!Nice! Impact's are made in the USA too
You are probably spot on with this assessment. I see the a 17 inch wheel with 37 inch tires with collars and its pretty close already to the fenders and trim. I would imagine a 20 inch wheel on 37's would make it even tighter to fit.I can’t say 100 percent, but I am pretty sure 37’s will rub no matter what offset you run without collars or springs. At the very least you will rub with any compression while off reading. The plus 12 offset will help but the 37’s will likely still rub. You have a better chance if you run BFG’s since they are not true 37’s, if you run Nittos they are even taller and will rub for sure. I think you will need springs or collars.
No difference between a 17 and 20 if the rims have the same width/offset and the tire size is the same.You are probably spot on with this assessment. I see the a 17 inch wheel with 37 inch tires with collars and its pretty close already to the fenders and trim. I would imagine a 20 inch wheel on 37's would make it even tighter to fit.
Stock lugs cannot be used. And stock does not come with a lock FWIWmy car is on its way to me from the dealer (yay!) i just bought a set of methods, but does anyone know if stock lugs can be used, and also if stock lugs include wheel locks?
Can gorillas or mcgards be used? I see they sell full set of locking lugsStock lugs cannot be used. And stock does not come with a lock FWIW
