raiderr0n
Looking to run TE37 (18x9 -1) with Toyo AT3 37x12.5 and hoping not to trim. Anyone have a similar setup and what mods were needed?
Appreciate the feedback!
Hopefully later this week. They’re not coated yetWhat’s the finished product look like? Any photos?
It'll be tight with no trimming but I'd recommend the Eibach front and rear springs. You might be good for regular street driving.Looking to run TE37 (18x9 -1) with Toyo AT3 37x12.5 and hoping not to trim. Anyone have a similar setup and what mods were needed?
Appreciate the feedback. If i went down to 35” tires there shouldn’t be any concerns on rubbing? Assuming 35s would be similar to stock but with 18” wheel instead of 17It'll be tight with no trimming but I'd recommend the Eibach front and rear springs. You might be good for regular street driving.
Eibach Pro-Kit for 21+ Ford F-150-Raptor (2.2 Inch Front Lift - 1.5 Inch Rear Lift) E30-35-060-02-22
Buy Eibach Springs E30-35-060-02-22 at Apollo Optics: Eibach Springs Description Increased Ground Clearance. More Fender Clearance for Larger Wheels and Tires. Precision Engineered for Improved Off-Road Capability. Excellent On-Road Stability and Handling. Made in U.S.A. Million-Mile Warranty...apollo-optics.com
Depends on the type of off-roading you do. If your flexing/articulating the suspension then the zero can become problematic. Tire size will limit travel in most desert/whoops/jumping situations the zero is fine if you aren’t running oversized tires. Hence why the 37 truck has less travel/different bump stops.While the "0" offset looks awesome, it does limit suspension travel right? Are you guys rocking those wheels just staying away from off-roading?
Are those Method 705's? If so, do you have a few more pics?Finally got these mounted. Shout out to @Pacific Wheel with the stellar hookup on the order, couldn't be happier. 0 offset was perfect for me. 17x8.5 on stock 35 tires.
