No ESP? I'm sure your dealer has the necessary tools to navigate the Cobb shroud. Check the light/connection first as it appears to be loose; ensure things are buttoned down tight then re-evaluate prior to sourcing out a new light.Something seems to be up with the same light on my truck recently. If I wiggle it the light will turn on. Anyone think this is the connection or the actual light? It seems to happen more or mostly on remote start.
I’ve got the Cobb radiator grill and air intake bracket installed. They were a PITA to get lined up for me. I’d like to take it all apart once so I guess I’m wondering if I should just also replace the light and use some dielectric grease in the connection. Video below.
I just rolled 40k so I don’t think it’s covered. Even if it was they would get pissed about the Cobb.
Same one started flickering on my '21. They replaced mine under warranty.View attachment 452937
Passenger side marker light finally went out after flickering for awhile. Was able to remedy by messing with wire behind grill, but now it’s totally out
Anyone have the part number handy?
Dealer attempted connection cleaning first time.
Seeking potential DIY solution or other options.
Thank you!
I have the ESP but a $200 deductible. Unless that light is $200 it may not be worth it.No ESP? I'm sure your dealer has the necessary tools to navigate the Cobb shroud. Check the light/connection first as it appears to be loose; ensure things are buttoned down tight then re-evaluate prior to sourcing out a new light.
