Gen 3 Arrived and just Ceramic Coated DIY
T
Torchy
Nevada
Yes sir, after you wash and dry use your hand with light pressure (or the baggy test) and feel the bonded contaminants. It will be rougher than paint without any bonded contaminants. Surprisingly, even sitting in a rail car or on a truck for a couple weeks will have contaminants that bond to the paint. If you wax/seal/coat a vehicle without removing them you're protection will not last long. If you don't remove the contaminants and then start polishing you open yourself up for marring the paint and contaminating your pads. After you clay and iron decon you then do paint correction if needed. Then polish and then use something like CarPro Eraser or Meg's M122 to remove all the oils from polishing. If you don't remove them, your coating isn't going to bond well and will not last. Same thing with exterior trim, when you coat it you need to thoroughly clean it and do a wipe down with the above-mentioned Eraser/M122 or any other product designed for that purpose. If you don't, then the coating won't bond well.
When polishing or paint correcting, ensure you are cleaning your pads after each panel or less depending on the size of the panel. I use compressed air, but you can also use a clean microfiber towel. I tend to only use a single pad for two-3 panels depending upon the condition of the paint and how much clear coat I'm removing.
Yep I feel ya. I used Carpro Iron X as well for this but didn't see much. Then again, it's hard to see purple on this color. But yeah I also used Wipe Out to remove the Sonax and then did one last Wipe Out wipe down too.
And yes I had 3 pads on deck for the 5" and 3" and used them all.
Cmart
Florida
Hey Guys!
Been waiting on this thing for months. Was 9/20 squad and it showed up 10/14 to dealer. It's 801, Moonroof, CF, Power tech and applique delete.
Because I'm a detail freak, I told them not to wash, just PDI and take off plastic.
Been planning the full ceramic job for months so this is how it shook out. Oh and by the way, you guys can do this all too. Not that hard.
Duraslic for paint, headlights, taillights, bumpers and fender flairs since their painted. BTW if y’all haven’t heard of Duraslic, it’s some next level stuff with a lot of science behind it. Stuff came with scrub test data card, water contact angle test data and oleophobicity data sheets. Also it’s the only coating on the market that’s oleophobic (rejects oils). They published an over 1 hour vid on YT about all the science behind it. Pretty neat. I like trying different ceramic coatings so this was the first time I have worked with it.
Cquartz DLUX for trim, plastics and grill
Geyon Repel Q2 for all glass
Geyon Wet Coat for wheels
Everything used:
She came suuuuper dirty off the truck.
Used Carpro Reset for initial wash. It's PH balanced and has no protections in it. We want the paint raw. Oh and also I have a water Deionizer from CR spotless. So water is filtered down to .000x PPM. Basically it can't water spot which is huge. Sorry crap pics. Had to wash in the shade of course.
Don't ask about the couch.... Got new ones, old ones stuck in the garage blah blah
Next up was a full buff/polish job using the 5" Rupes Mark III with yellow pads for bulk work. Griots G8 2" for small stuff with Rupes yellow. Sonax Perfect Finish compound. The Sonax works great but was a little dusty. 3D One is less dusty but Sonax might be slightly more fine/polish oriented. This took a while! Like 7-8 hours. No during pics but these are the afters.
Next up is the coating. The glass was werk! Took like 4 hours.
Plastic was only slightly less labor. I did hit it all though. All hood plastics and cowl, tops of bed, tops of back bumper with plate surround and the grill. Pro tip, see the brush in the earlier pic? Drip your ceramic on your brush and paint it onto the grill for full coverage to get in intricacies of the grill, wipe excess off grill with microfiber and immediately wash brush. Then just catagorize that brush as a ceramic brush. You should get a few uses out of it before throwing away.
Duraslic on the paint went on and off like a dream. Very easy to work with and has a very fast flash time, which I like. Like 30-90 seconds fast. Also they claim only 1 coat needed and this is the pro grade stuff, 9H, that's supposed to last 7 years. Don't ask me how I got it.... was technical
Geyon Wet Coat was just a quickie because I'll probably be changing the wheels. If I was keeping these then Cquartz DLUX would have been used. I will put DLUX on my new wheels.
Again no pics of the during but this is the afters. I'll try to get some better ones but I'm doing a First Edition Bronco tomorrow and it's my only day off. More coming!
I wasn’t sure if this was a commercial for the products you used or a Matt Moreman Obsessed Garage post . Congrats on the truck, looks great.
Jake226
IN
Beautiful! That AMB looks deep when it’s all cleaned up.
Congrats on the ride!
Ron Lanza
Newnan, GA
I finally washed my 2020 SCAB for the first time in 3 months!! I have the ceramic coating kit, but haven't had the time to apply it !!!
OEMPlus Raptor
OEM preferred....
Oxnard CA
I'm a detail freak too....I HAD A BAD EXPERIENCE WITH CAR PRO DELUX on my plastics. I would never use it again. It turned my plastics chalky white and I had to replace them. Not sure why.
You by chance watch Obsessed Garage with Matt M on YouTube?
I like what you did other than the fact I don't care for CarPro Delux.
Good Job!
OEMPlus Raptor
OEM preferred....
Oxnard CA
I was wondering why CarPro says not to use Dlux on new textured plastic and their response was:
“Hi David, great question! MANY people do use this on new plastic however the reason we have that disclaimer is because of the risk… let me explain.
It is possible that after a year or so in some instances it can get a whitish look. This only happens sometimes so it is my theory that usually it is because there was some dressing or something still on (or to be precise - IN the pores) of the trim that wasn’t fully removed before DLUX was used. I theorize the it is also possible that the plastic me “gas out” for a year or so after being created and potentially that gas could get caught between ceramic and plastic and creating tiny microscopic bubbles that start to make this slightly whitish look.
REGARDLESS…. the point is that this can happen on occasion and when it does I do not have a sure fire way to give you to fix it. If you could polish it with an abrasive polish like smooth plastic or like paint or glass then its super simple to fix… but with textured plastic it is VERY hard to polish it off without making the plastic look weird.
Once the plastic gets older I feel like its not as much risk and there’s also not as much to lose. What I personally recommend on new plastic is this Ultima Tire & Trim Guard Plus - 12 oz. It is nanotech but it is not ceramic. It will not last 12-24 months but it WILL last 3-6 month on a daily driver. It is very easy to apply, very durable, and zero risk.”
I haven’t personally seen this issue while doing coatings on trim, but I haven’t used Dlux and was curious why they didn’t recommend on new plastic. I have Normally stayed with C4 for trim.
The paint didn’t have any bonded contaminants requiring a clay? I’ve never seen that either on a new vehicle.
This happened to me! I felt my plastic was prepped properly and I used CarPro eraser before I applied. You're right though. Once it's on and turns white it's near impossible to get off. I reached out to CarPro (Sky's the Limit) and was send the Ultima Tire and Trim. It was a nice gesture, but I wish you could see my cost for replacing all of the plastic bedside caps and other trim (NOT CHEAP). My instruction booklet for CarPro DLux didn't say anything about not applying to textured plastic. Maybe it has been revised since. I still have it.
