Still only work with 2017 models?
This is common. it is usually not the actuator or anything electrical related.Has anyone had one of these fail?
I've had this kit for 3 years and worked great. Recently my tailgate actuator stopped releasing my tailgate. It would sound like it is firing but tailgate would not release. Dealer replaced the catuator with a new one and within hours the same problem happened.
Curious if this upfitter kit is responsible in some way and if anyone has any tips to troubleshoot.
Sent from my Pixel 5 using Tapatalk
Interesting. Af first the actuator was firing but later on the actuator was not even working, indicating it burned out.This is common. it is usually not the actuator or anything electrical related.
the rubber stops on the tailgate can swell and apply too much pressure on the tailgate. Causing the latch to get “stuck” as it can’t overcome that pressure.
Yea. That tight fit pit a lot of stress on things.Interesting. Af first the actuator was firing but later on the actuator was not even working, indicating it burned out.
I'll check the rubber stops. What's the fix?
Thanks I'll check them. What's the trick to releasing the tailgate ooen from the bed when it's stuck?Yea. That tight fit pit a lot of stress on things.
some have the rubber stops replaced, or shave them down
Push in on the tailgate to relieve the pressure. Then hit the tailgate buttonThanks I'll check them. What's the trick to releasing the tailgate ooen from the bed when it's stuck?
