Gen 2 SCAB makeover…totally not ripping off Geoff’s 2.5 build!
91Eunos
91Eunos
Hill country, Tejas
Another tiny step forward… Got the front bumper and stock intercooler removed, as well as the transmission cooler lines, and a few other small bits so I can finish cleaning and prepping the frame for the rebuilt motor install:
…clearly some transmission fluid remaining in those lines, LoL.
Since I gotta clean up the mess anyway, I’ll try to get to the front differential cover this evening too; depends on how long my afternoon errands take to complete. I gotta keep moving on this…the piles of parts is becoming worrisome!
91Eunos
91Eunos
Hill country, Tejas
Swapping out the front diff cover was a bit more involved than anticipated. I honestly thought it was gonna be a 1/2 hour or less project since I had easy access to all the bolts with the bumper and intercooler out of the way.
LoL
Draining is always a messy pain in the ass with a cover that doesn’t have a drain:
But what I didn’t plan on was having to partially drop the power steering rack to even get the stock cover off. And in their infinite wisdom, some random Ford engineer decided that one of the bolts should have a 21mm head, and the other a 22mm. And put in with well over 150 ft/lb of torque…good God.
The diff itself only required a little bit of cleanup though…pretty clean fluid too despite the miles. I’ve never changed the front diff fluid in 115K miles!
Note: You’ll have to push the rack as far back and upwards as you can get it to go on the RH side…and drop the LH side as low as you can as as well, to get it as far forward as possible to clear the diff cover:
Spicer cover is a tight fit, but no clearance issues:
Also, while the lower fill plug is easily accessible from the bottom with a regular 3/8” square drive, if you want to use the top plug like I did, you’ll need one of these 3/8” to a 9/16” bolt head adapters…or a very thin-headed 3/8” ratchet I suppose:
Thought I was gonna have to break out the fluid transfer pump and a hose, but a small funnel just fit into that top fill hole. Mine took just over 2 quarts to fill.
Ops checked by rolling it back and forth a few times and checked for leaks several times…seems gtg, but will check it again mañana.
More to follow…
91Eunos
91Eunos
Hill country, Tejas
Well crap… Just heard back from the folks building my short block. Gonna be 10-12 weeks (!) before they can get to my motor. :confused:
Since it’s gonna be such a long time anyway, I’ll ask them to paint the block Ford Racing Blue after it’s been checked and passes muster. Probably the “old” Ford Blue, but I actually prefer the darker “corporate” blue myself:
Edit: they don’t do paint…guess I’ll do it myself when I get the block back. Will paint the new valve covers too.
Guess I’ll drop the cab back onto the frame this weekend, but leave everything disconnected except for a couple frame bolts, and roll it out of the garage for a few weeks while I knock out some other projects.
Silver Lining: Plenty of time to gather the rest of the parts, and may even be able to delay this long enough for Boundary to come out with an oil pump and crank timing gears!
downforce137
In Diana
pretty sure you want to fill to the lower hole on that front diff cover..
the upper plug is for a lifted application with a crazy pinion angle.
you are probably overfilled at the upper hole at a standard pinion angle..
also, corporate blue is the one youll want, but id suggest just doing the valve covers or something as the engine is already aluminum and doesnt really need a coating..
91Eunos
91Eunos
Hill country, Tejas
also, corporate blue is the one you'll want, but id suggest just doing the valve covers or something as the engine is already aluminum and doesn't really need a coating..
Good to know… lucky for me, this is an extremely easy situation to remedy! LoL
91Eunos
91Eunos
Hill country, Tejas
I’m not actually serious about those GT cams, but it was an interesting find when I was pricing out replacements for mine. They’re not in horrible shape, but since I’m already this far into the rebuild, kinda thinkin’ about it.
Also, thanks again @dillard09 … the head gaskets showed up yesterday!
You’re awesome my man.
96,789
60,751
RCDoug
