GEN 2 Gen 2 pro eagle jack no drill bed mounting plate
Jspeers89
Very nice setup. Considering it as anchor for fridge in the truck bed. What's the cost?
Hobert
I checked with JDS. The ones pictured are ones he makes (not Kyle Raymond's). He quoted $50 a pair above.
Hobert
Wouldn't we need 3 to make it work?
Depends on what your strap setup is. If 4 anchor points you can use two straps to secure the spare. If going with a Y-shaped tire strap, you will need a middle anchor point (between bed bolts) on one side, so you won't be able to simply use three anchors at the bed bolts. That's why Kyle Raymond's solution above has the rounded bar between bed bolts...
SOAKINRED
Orange County CA
Kyle Raymond's spare tire mount
Looking into this further, those anchor points look very similar to Kyle Raymond's spare tire solution.
I have Kyle Raymond's spare tire mount, its perfect.
Spartan1
Mars
Any tips on bed bolt removal and replacement on a 2017? Is it torx 50 plus? Will I have to replace the bolt or can it be re-used?
